amiry36 wrote:Yes. You can do it with the universal one too. Honestly you dont even need the universal one. When i lifted my engine, i used a long strip of heavy duty chain wrapped around the engine mount brackets, since my plenum side bolts were missing. If you have one laying around, just use it and save a couple dollars. If you dont, you can also do it with a ratchet tie down strap found at walmart for like $4. Waaaay cheaper than the universal one.
Actually, I already have a set of simple HD chains, brackets, and grade 8 bolts I've used in the past to pull numerous motors, so if I wanted to pinch my pennies, I would just figure a way of using those. I've even seen people use nylon straps wrapped around the plenum to pull the VG30DETT. After using the brute force and jiggle methods to separate and mate engines, mounts, and transmissions, I think it's nigh time for me to spend a little to make it easier to R&R motors as I have two projects to do. A load leveler is only about $50-80 shipped so not that big a deal, and can sell it off after my second project if I'm really strapped for cash or storage space. But the ease and convenience it would bring to engine R&R is worth the low-cost expenditure for me.
So it's now figuring out where there are 4 relatively equal mounting points for the load leveler...
