M45Caliber »
https://forums.nicoclub.com/m45caliber-u98401.html
Thu Jul 03, 2008 1:29 pm
I getting spooked right about now with this M45, which I bought 3 months ago. It now has 33K mile on it (it's an '03). This is the SAME M with the post for the gauge issue (1/2 the cluster out; no AC..) last week.
Today, while driving down the highway at about 75 mph, the car just completely loses power -- the engine just shuts off. I turn off the radio (so I can hear what's happening), then place the transmission in neutral so I can coast (I was already in the right lane with my exit coming up in 1/2 mile...) since I'm in neutral and pointed straight ahead, I turn off the ignition, pull the key, re-insert the key, turn the ignition back to "on" and the motor is running again -- I rev it and hear it/see the tach move. Back into Drive and motor on to Hooters for lunch with friends. After lunch, I drove it straight to Checkers Auto so they could check my battery. Turns out the battery is the ONE thing the previous owner did not have changed out at the dealer - it has an "Interstate" brand battery in it, but none of the Date stickers were pulled to tell me how old it is. However, per the electronic testing machine at Checkers, it tests out fine. "Within 100 cranking amps of a new one" -- keeping in mind it's 110 degrees outside and I've been driving on the freeway, so this battery is HOT.
Is there ANY WAY my key fob might be sending (or not sending) the right signal and this crap is happening to me? Would changing the batteries in each fob help at all? Should i change out the car battery and pray to the electronic goddess of Ohms to bless my car accordingly?
Grasping for straws (volts, amps...), gents.
I was not offered an extended warranty, and although this puppy only has 33K on her, she's past the 4 year anniversary by about 6 months.
Could a dealer sell me an extended warranty now, given the low miles?
ANY viable thoughts appreciated....
