91240 »
https://forums.nicoclub.com/91240-u10728.html
Sat Oct 11, 2003 10:51 am
Hey. Get comfy, this is a long one... Got the same problem, and I've read lots of other posts about it. I've had my '91 KA24DE for about two weeks. My problem has been unstable idle (hunts around from 400 to 1000 rpm, and stalling - both at idle and freeway speeds. After it stalls, it won't start for from 10 seconds to twenty minutes. Regarding the unstable idle I've seen posts on the cause being everything from MAF to tire tread wear (sorry, exaggeration to make a point). Not familiar with car yet, so took it to dealer (aka parts replacer). Mechanic did actually see it stall (forunately), twice. No spark (I had been ready to replace the fuel pump. This feels like a fuel prob to me.) Took his advice and ordered new coil/power xsistor. He replaced them, problem still there, so "You need a new distributor". OK, replace the dist - problem still there. HOWEVER - unstable idle problem GONE (crank angle sensor?). Now idle is rock solid and car stalls less frequently, but still does stall from time to time. Still reeeal suspicious of fuel pump. In my car I can hear the pump during the 5 secs it runs when you turn the key on, but its very quiet. Need the car to stall someplace quiet so I can tell if the pump's running . My question is; is the ECU sensing fuel pressure in some way, and shuttting off the spark, or; is there really an ignition problem. Any help would be greatly appreciated. I'll post what I find out.
