xxtrizz »
https://forums.nicoclub.com/xxtrizz-u10757.html
Mon Sep 06, 2004 4:50 pm
Honestly its not that hard to do a DOHC swap but it depends on what you want to do. THere is going to be more aftermarket availability for the DOHC. I preffered to stay with my sohc because I wanted to keep my AC without fabbing up BS, or modifiying anything because im going to have to much time put into the car as a whole rather than just engine setup.
It also depends on what your gonna do. Turbo I assume? You gonna rebuild it make it performance or just turbo it? If your going to jsut turbo it then I would get a low mileage DOHC. But if your considering any aftermarket then it is applicable either way. What are your goals do you have a job to save money up or are you just thinking about what you want to do. Educate yourself more about the individual engines and then decide.
