engine shampoo
Jostudly
Car: 2009 Nissan Rogue
Is is safe to get my engine shampooed? There is a lot of grease under my hood and would like to get it cleaned up but not damage any sensors or electrical components. What products are safe to use? Not sure if the garage's use a spray or do by hand.
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
wouldn't go near this idea. id scrub it by hand if i wanted too.
can you take a pic of the 'grease'? you might have a leak
Jostudly
No there is no leaks just a lot of road grime I want to get off. Is these a degreaser that you would recommend to do this by hand?
ImStricken06
2016 Kia Sorento
oven cleaner, wd-40, simple green, etc.
i woudnt touch electrical or plastic components with anything other than something like simple green. simple green is also known as the 'THING' to use to clean brake caliper pistons. it doesnt harm the rubber seals for the caliper pistons, so i dont see it causing harm to plastics in the engine bay.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
ImStricken wrote:oven cleaner, wd-40, simple green, etc.
How about DP engine degreaser? Eco friendly and made for cleaning stuff under the hood.
Qashqai
I am always cleaning the engine bay whenever I wash my car. It is as celan as day one. If you never open the hood for two years, and one day you realize it is dirty, It is not something unexpected right?
darylzero
Jostudly
I will try the Simple Green hopefully it will not fade or damage the plastic. Can this be used on the rubber hoses as well?
ImStricken06
2016 Kia Sorento
Jostudly wrote:I will try the Simple Green hopefully it will not fade or damage the plastic. Can this be used on the rubber hoses as well?
yes, simple green is great on rubber. that's why its used by everyone when cleaning brake calipers. (brake calipers have rubber hoses, rubber seals, and its absolutely CRUCIAL to not use products that will regrade rubber.)
Jostudly
Well I finally got my engine bay clean today. I ended up using Spray Nine instead as I heard Simple Green may damage the paint around the hood. It took me 4 hrs and had to spray it about 6 times. I had about half and inch of grease built up under my hood. I think this was actually put on when the dealer rust proofed it. It turned out pretty good and I will post some pics later.
Jostudly
Here are the pics:
Jack2Soneal
Car: Mercedes Benz S series
Qashqai wrote:
Sat Sep 08, 2012 5:22 pm
I am always cleaning the engine bay whenever I wash my car. It is as https://automobiledecor.com/best-engine ... s-reviews/ as day one. If you never open the hood for two years, and one day you realize it is dirty, It is not something unexpected right?
yah You are Right Cleaning good for the car but regularly clean it makes more bright and as well look good. Daily wash there was no mud will remain so good idea to cleaning.
Jack2Soneal
ImStricken06 wrote:
Sat Sep 08, 2012 8:10 am
i woudnt touch electrical or plastic https://automobiledecor.com/best-engine ... s-reviews/ with anything other than something like simple green. simple green is also known as the 'THING' to use to clean brake caliper pistons. it doesnt harm the rubber seals for the caliper pistons, so i dont see it causing harm to plastics in the engine bay.
Thanks for the post, It was good for me to clean my car safely. Would you please suggested me some accurate And authentic products.
yearoftherat
Car: 2015 Nissan Rogue SV AWD
Jack2Soneal wrote:
Tue May 22, 2018 11:29 am
I use Sonax Engine Cleaner
https://www.sonax.com/Product-Search/(l ... ld-cleaner
macgiver
mac , I'm lucky not to have too much of heavy grease buildup because number one I'm always wiping around an area that I'm wrenching on , and if nearby has that "sweat of grease" I'll wipe it too. We get beuacoup dust & sand here so a car shampoo for me , don't really like any degreasers even (concerned with el. connectors) Is that I use finest garden hose spray - we got great 80psi !!!! at the spicket round here.I'll have the motor warmed , 4min. - not HOT. So water drys very fast..... in Desert :rotfl
That kind of "cutting-mist" quickly knocking off surface dust -that's it for me. :spitout:
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
Maybe I live life on the edge, but my QX4 was nasty under the hood. I sprayed it all over with Gunk Degreaser and sprayed the heck out of it with my water hose in the driveway. I did the same thing with my Mitsubishi Endeavor. I ended up not having any issues. Maybe I got lucky so I'm not endorsing you do it - I'm just saying I did it and it worked.
prj
Car: 2018 Nissan Rogue. 2004 Nissan Titan
I use Gunk brand engine degreaser. Spray it on while the engine is hot then head over to the car wash and hit it with the power sprayer. Been doing this for 20+ years on cars and never had a problem.
Return to “Rogue Forum”
