destroyyourmind »
https://forums.nicoclub.com/destroyyourmind-u81700.html
Sat Jun 07, 2008 1:10 pm
haha I don't really know **** about the whole obdII and obdI i just know in nc I dont have to pass a smog test thats all I really keep up with. the plugs are new and there gapped fine . it could be a vaccumn leak somewhere because its really shaky at idle the shifter will bob around and you can feel the car moving. it wasn't like this when I bought it a few months ago. I idle at 700 but every then and again it will start and die off and I'll have to give it hell to start back up this happens every 2 months or so compression is 175 on all four cylinders completley stock minus air filter on the stock tubing. it throws flames in the upper rpms anywhere from 4-6 grand.
EDIT for to mention new wires distributor cap and rotor motor has only seen synthetic oil 5w 30. it wouldn't just not spit a code it wouldn't even connect with the ecu it kept coming up with an error. car had subs from original owner someone stole them from dude ripped all the wiring and some of my interior **** doesn't work. IE light dimming switch climate control lights.
