Engine Shaking
BigLilCar
Car: '07 VERSA
Bought used '07 Versa S with 3,000 miles. Noticed engine shaking when coming to a stop and a clunking noise when backing into a parking spot. Nissan diagnosed as a broken engine mount. Replaced engine mount. The clunking stopped but the engine still shakes. Nissan claims it is the nature of the engine.
Does anyone else have this problem? Slowly come to a crawl like you are approaching a stop sign. Right before you come to a complete stop does the car seem to be shaking?
Also mileage has only been 22mpg for the last 5 fill ups. Nissan claims I still have to break in the engine and wait for the "summer blend" of gas. Very disappointed.
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
BigLilCar wrote:Bought used '07 Versa S with 3,000 miles. Noticed engine shaking when coming to a stop and a clunking noise when backing into a parking spot. Nissan diagnosed as a broken engine mount. Replaced engine mount. The clunking stopped but the engine still shakes. Nissan claims it is the nature of the engine.
Mine gets 38mpg and it only has 700 miles on it that is complete BULL ****
alonsorules8
Car: 2008 Nissan Versa SL HB
BigLilCar if you run an ethanol blend gas in your V it can cause the engine shake you described. I had the same problem in Ohio with 10% ethanol 90%gasoline and by switching back to all gasoline problem went away.
amilcaronline
Car: Tiida 2007. Manual 6M. 1.8SL
I had the same problem. I have a 2007 Tiida and they diagnosed the motor mount. After 2 visits to the dealer, the replaced it, and the noises coming from the motor dissapeared and the shaking also gone away. The car is silent now.
daan
Car: 08 Nissan Versa S base
The sensations you feel sound really like bad motor mounts. My other vehicle (Mazda 5) needed them when it was less than a year old. Your car should still be under warranty so you shouldn't have to fork out anything to get this fixed. Oh yeah, I'm only averaging 26mpg with my versa so I don't know where these 30+ guys are coming from.
xtwoonamatchx
Car: 2007 Nissan Versa S
dunno about the shaking... but theyre getting thyre good milage from the CVT, and i believe the automatic gets good gas milage too... the 6 speed gets the worst... and as to the OP... you driving a 6 speed? cause if you are, you need to put the clutch in a little earlier =p
blockmachining
Car: 08 Versa, 02 Quest, 1997 Ford F250 Supercab 4x4 Powerstroke Diesel, 1948 Dodge Pickup, 1987 Honda Su
Your engine should not be shaking. Mine is smooth as silk. I can't even feel the engine running through the steering wheel. The comment on the gas blend very well could be your problem. Good luck getting your car fixed. Over 5700 miles, I am currently averaging 30.00 MPG. It's getting better as the miles add up and the summer blend of gas hits the injectors.
