K03sport »
https://forums.nicoclub.com/k03sport-u129071.html
Mon Jun 15, 2009 2:58 am
well, the engine is off balance and for a 6 to be off, that means that one (or more cylinders) isn't firing like it should.
It could be a bad spark plug, plug wire, clogged injector, etc. there are a whole host of things it could be. But if the truck is old or high mileage, the rubber engine mounts do wear out.
I'm not sure if they are fluid filled (hydraulic) or just rubber, but they do go bad over time. Shoot, it can even be a transmission mount.
Does the engine smooth out at higher engine speeds or does it shake bad at any rpm?
