FUNGC wrote:they are mint. no cracks, and not even broken. the first engine i put in shooked alot. this one still shakes but it doesnt shake as much as the first engine. both are running very rich.
i also smelt the engine oil of the first engine and it smelt like gas...
im pretty sure the rings arent gone on my engines cause it would have caused alot of blowby, and it would have burnt oil, which if irc that blue smoke is burning oil, and black smoke is running rich.
if blue smoke coming is fuel and oil mix together...BADif black smoke coming out is...need oil change...when as the last time it change?if white smoke coming out is either your hg is crack or turbo is out.you are running to rich mean your injectors sending to much fuel to the motor and your spark plugs probably are fault out and is not given enough spark to burn fuel. So now at this point fuel and oil are mixed.
so now replace new spark plugsflushed oil, put new oil inif you are running with a sr and is tuned with safc or romtune...it need a good tuning again.
cause this happens to me because i'm running with a sr20 with a safc.
