BaliLover »
https://forums.nicoclub.com/balilover-u6785.html
Wed Oct 27, 2004 5:19 pm
It could be a leaky injector o-ring or 3. One way to check, is with the car running, unplug one coil pack at a time. If you unplug the coil pack, and nothing happens to the motor, that injector is likely to be leaky.
THe other way to tell is to turn the car off, and remove the fuel rail mounting bolts but not the fuel lines. Lift the rail out of the manifold enough to see the bottom of the injectors, and with the rail positioned like you were going to drop it back in, have a friend turn the key to the 2nd position (the one before start). If your orings are good, you will see a solid squirt of fuel, if they are leaky, you'll be able to tell due to the pouring of fuel out of the bottom of the rail.
I recently had my setup tuned and installed new injectors and had 3 torn orings and it idled VERY rough, but ran fine.
