My wife drives a 2007 Quest that I had a friend, mechanic, replace the timing chain tensioner through the access cover. Reason being that the tensioner and chain rattled at startup when cold. He did one on a Maxima and was successful, so I figured I would let him fix mine. other than the rattle at startup, van ran perfectly.
When he returned the van, I noticed that the van felt like it was idling rough. you can feel the engine shaking in the steering wheel. you can also see the engine shaking under the hood. Idle is around 700-710 RPM's. The exhaust sounds great; no spitting, no missing or anything. has tons of power when you get on the gas. only issue is it seems to idle rough. He brought van to Infiniti, where he used to work, put on computer and it says one of the banks alpha reading is 100 and the other is 120. Not sure what this indicates.
He is where I'm at...... I'm convinced that the timing chain jumped a tooth when he replaced the tensioner. Not sure if there is that much slack in the chain to fall off the sprocket at the crank and then when he put the new tensioner on, it was off a tooth. Everyone I speak to tells me I'm crazy; that if it was off just one tooth, it would barely start and if it did, it would run really bad, regardless of the tooth off was retarded or advanced.
Does anyone have experience this to know for sure? back in the day, you could use a timing light to troubleshoot, but not sure if there is anyway to tell if timing is off without removing cover. If not timing, where would you recommend I check?
