Engine shakes - anyone know WT* is wrong ?
cccp.spb
Car: 2006 M35
I've got 03 G35 coupe AT
When the car is in Park, Neutral or stopped at the light - engine shakes (rpms are standing still tho) and those shakes are uneven...
shake... 2 sec interval... shake.... 1 sec.. shake.... 5 sec.... shake.... 1 sec... shake... 1 sec...
you can feel it in the steering wheel and even with your a** sitting in the seat....
just driving me nutz...
at first I thought something is wrong with the engine.... but I checked - everything seems ok...
anyone else has this ?
biggie
Mileage? That may determine what would need to be replaced.
Otherwise maybe engine mount issue?
cccp.spb
Car: 2006 M35
biggie wrote:Mileage? That may determine what would need to be replaced.
it's got 90K miles
joe603
Car: 2014 Durango R/T
Does it do it with more fuel? Try cleaning your MAF sensors...be careful not to damage them. Also check your intake tubing for holes/leaks. Maybe run some injector cleaner through as well. Sounds like the car is either misfiring or getting slightly starved from fuel, causing the shake/judder.
cccp.spb
Car: 2006 M35
joe603 wrote:Does it do it with more fuel? Try cleaning your MAF sensors...be careful not to damage them. Also check your intake tubing for holes/leaks. Maybe run some injector cleaner through as well. Sounds like the car is either misfiring or getting slightly starved from fuel, causing the shake/judder.
Yeah, I thought about that too - seemed like the air/fuel mix is somewhat is unbalanced and that causes the shakes.
How do you clean the MAF sensor?
Thanks
biggie
They make a MAF cleaner spray, and it should have instructions. A quick search should find it.
Also before or after that you may want to try to reset the ECU, there is a gas pedal procedure to do to reset it.
cccp.spb
Car: 2006 M35
biggie wrote:They make a MAF cleaner spray, and it should have instructions. A quick search should find it.
I'm sorry, what is ECU and how do I reset it ?
Thanks
biggie
cccp.spb wrote:I'm sorry, what is ECU and how do I reset it ?
Thanks
ECU is what controls the engine.
Reset procedure found here:
post5682489.html
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
get your ecu scanned at the local autozone. I'm sure it has to do with your cam angle sensor. Mine engine did the same. It took a good 6 months before i get a cel but the whole damn week by week it gradually got worse untill it would fail and just slowly die and shut the motor off.
When your codes get scanned and you see bank one or bank two pending it's time to change them. You could also clean the throttle body and maf.
CAM ANGLE SENSORS CHECK EM! :dblthumb:
Poyzinous
Car: 2004 G35x Premium 1976 Classic Red 36 inch #18 Radio Flyer Wagon...
if the idle is steady and you have no MIL lamp illuminated, engine mounts are a good possibility.
