alex4 »
https://forums.nicoclub.com/alex4-u70431.html
Wed Jul 30, 2008 6:54 pm
This is a problem I have been chasing for a while, I have tried doing what searches recommended. Kinda getting stuck...
Originally, the whole front end would shake real bad after starting the car about 1-2hours after driving it. It would shake under 1500rpms until it would just randomly start working wonderfully. I would have greatly reduced power, but then somethign would just start working and it would be an instant power boost. Wouldn't do it from a cold start or turning the car back on right after turning it off.
I took the car to Chek-Ups because they will diagnose your problem for 65$. They said it was leaky intake manifold gasket. The intake manifold gasket was a little leaky, plus the last owner had RTVed all over it trying to seal it (but failed). I spent forever getting all that manifold crap off, and when I finally finished, it still didn't run right.
After using the search button like a good little NiCO member, I did all of the easy possible fixes I found from past threads.I tried running premium gas with no ethanol.I tried putting in lots of super concentrated fuel injector and fuel system cleaner.Today, I put in beck/arnley remanufactured fuel injectors (Why would nissan put phillips head bolts on something so tight and important like injectors? Lame. Now it has hex bolts in muahah.)
NOW it shakes all the time, but only when not moving. It's as if it runs fine until some idle-control thing turns fuel flow down to save gas while sitting still, and that makes the injectors sputter. It drives fine, and under any load it doesn't shake. Also, the new shake is not as violent.
The only thing I can think of now is that since I bought the cheapest injectors, some idle control thing is calibrated to work with better injectors with tighter clearances.Is there any way I can disable some idle control things like that to see if that will cure the problem? I know it would slightly decrease my gas mileage, but that isn't the end of the world- I just want to keep the wheels turning.
I guess I could try to get AdvanceAuto to take my fuel injectors back and give me a refund, then I could try new fuel injectors.
Or also does anyone have any other suggestions about diagnosing the problem?THANK YOU AHEAD OF TIME, OH 240 GURUS!!
