They must have messed somthing up when they put the new clutch in... Use the Search and type in "Runs rough"gehzumteufel wrote:well so i got my new clutch and flywheel and shifter installed on wed. it idled and ran fine before that other than the clutch problem. now it idles REALLY rough and runs ****ty. it acts as if its mis firing. new plugs were installed about a month ago. i am out of money. PLEASE HELP! the sound it makes is like a toyota camry with a bad exhaust leak.
Check your MAF that's what I would check first...gehzumteufel wrote:well what can you mess up? you disconnect battery, remove driveshaft, disconnect transmission electrical connections, remove transmission. nothing to it. theres only the 4 sensors on it but those wont effect the way the damn thing idles and runs the way my car has been effected
alright well maybe they knock the timing off some and didn't fix it... so just re-check that. i am getting pretty good at timing now that i been learning it for the past 4 days. lolgehzumteufel wrote:well did some testing and its the injectors. and btw dreams i had it done professionally so i dont know what exactly happened.
