Engine running rough, sputters, shakes, misfires..after replacing injectors
ii_cantwait
Car: Gray 1990 HS13
I replaced my fuel injectors on my 90 240sx (ka24e) today. They were a used set of injectors. I followed the DIY fuel injector install that can be found in the archives. After replacing the injectors, i put everything back and started it up. The engine was sputtering, shaking violently. Sounds as if it was misfiring and not all the cylinders were firing up. The idle was very low as well, around 500 rpm. I also tried wiggling the injectors and it didn't make a difference. What could be the problem, please help.
THanks!
s13sr20chris
what caused you to replace them?
ii_cantwait
Car: Gray 1990 HS13
they were leaking
NISTECH
The used injectors may be defective. Where the plastic tips in good shape on them?
ii_cantwait
Car: Gray 1990 HS13
3 out of the 4 injectors had cracked plastic tips because the sender failed to pack it properly. Those plastic tips actually make a difference? i thought they were just covers. Anything else i should check out before putting back the old ones?? Was there anything that needed to be done with the fuel pressure before starting the car up ??
Modified by ii_cantwait at 12:31 AM 6/11/2005
NISTECH
Your injectors are junk. Those tips control flow/pattern. No you just cylce the key a couple times to allow the system to build pressure then fire it up. If you didnt do that it wouldnt make much of a difference except your crank time would have been longer. But once it started running you wouldnt have any run problems as a result of not doing it.
Touchdown038
Car: Computers, cars, sports
Man I would go back and try to get some new injectors from whoever you ordered them from. If they failed to pack them properly they should replace them no charge.
SlideSociety
hope it wasnt from an ebayer and i hope you had shipping insurance...
