moso »
https://forums.nicoclub.com/moso-u137641.html
Sun Nov 15, 2009 8:43 am
chances are you broke an o-ring, its really common. unbolt and remove the fuel rail and the attached hardlines form the intake. leave your fuel lines connected. place a rag under your injectors and have a friend key on the car but dont crank it. when your fuel pump pre loads the system it will cause the leaky o ring to wiz gas all over your rag. remove and reinstall your injector with new rings. dont be supprised if you have to do it a few times, try using baby oil, vasoline, or just plain motor oil. WARNING- if you have keyed on and off your car a few times you can fill your cyl full of gas and possibly break something if you crank it. remove all your spark plugs, put a rag over the holes, and crank the car to expel any fluid.
