fabio420 »
https://forums.nicoclub.com/fabio420-u28809.html
Fri Nov 04, 2005 8:23 pm
First, I want to apologize for the size of this thread, but I just want to give all the info possible for whoever can come up with a solution. So here it is: 2 months ago i blew a piston. So I replaced the pistons, and reasambled the engine. Now, the head had work done to it(port n polish, 3 angle valve job,dual titanium springs, .5mm oversized nitrited valves) and I used a metal head gasket on the rebuild. I also installed an oil pressure gauge. Now for the current situation. The car is running. When it's still cold it runs better. However, It won't idle if the ac is not on (it brings the RPMs to about 1000) After running for like five minutes, it starts to act rough and it "hickups" in cycles. Whenever it does this, the oil pressure drops and the vaccum jumps. If I am not moving, the car idles almost fne in neutral with the ac on. If I have it in drive, the car stalls out. btw, it's an automatic. I checked for vacuum leaks with starting fluid, and found nothing. I'm not really sure what it could be. My oil pressure drops to about 20 psi when it gets hot, but I can't tell for sure, since I've only driven the car for about 20 miles in 10 minute intervals. I've tried to adjust the timing, but I don't know if I'm using the timing gun correctly. The car is turboed, but I don't think this is the issue, since it was boosted before with no issues, and I haven't touched the turbo parts and I'm tring not to boost ( keeping it below 3500 rpms for a while). The plugs are NGK gapped at .040. I'm kinda stumped as to what it could be. The car will run with the ac on and if I have it neutral when standing still. If the ac is off (RPMs below 800) the car stalls. Sometimes, if I'm in drive and not moving, the car will stall. The car is drivable, but it shouldn't run like this. If anyone has any ideas for me to try, I'd love to hear it. I'm not to the point of taking it to a garage yet, being that I assembled this engine myself, and feel like I can do most work on it. I JUST DON'T KNOW WHAT TO DO WITH IT! Please help me!
