Is it possible to compare the engine RPM VS the Turbine sensor data to see how the torque converter is doing? I know the torque converter is always slipping (Creating heat) except when its locked to for better efficiency.
Could comparing the turbine sensor RPM and the revolution sensor RPM tell us anything?
