He also stated he drove around for an hour with the sound, took it on the freeway, then took it up to 6k rpm.tollboothwilley wrote:Go to the dealer. Start the Oil Consumption test.
Driving that low in oil can cause very serious issues...
You said you check the oil level before you left, was it low then?
Don't be surprised with the new engine doing the same if it ends up 3 quarts low and is run for an hour knocking with a run up to 6,000 rpm.silverbullit05 wrote:wow the tech had told me that the bottom end is the redesigned hr however the heads and intake are the same. but in any case im happy that they are warrentying it and im getting the new engine. i just hope this problem is fixed w/ the new engine. ill be pissed if this does not and it does this again out of warrenty
Three issues I have with this comment. One is you are a little bit low on oil at the start. You have a funny sound and drive around for an hour with the sound. With the sound still present you then downshift into 4th at 60 mph (what is the rpm in 4th gear at 60 mph?) and then you take it up to 6000 rpm and maybe above (what is the speed at 6000 rpm) which depending on location means probably exceeding the posted speed limit and possibly falling into the criteria of warranty exclusion (racing of any sort) which is a broad enough term for possible inclusion of a warranty exclusion. Now with low oil level you refill your oil but the sound doesn't change, so we drive home with the sound still present. Don't know about your warranty, but did you think about towing it home at any point during this time period?tollboothwilley wrote:I disagree with Perry.
I think that you had a legit issue. I have 135K miles on my car and I romp the thing all the time. It just happens that you got a bad engine. If you can't take this car to redline then redline shouldn't be there. Sorry you got a bad engine, but the new one shouldn't have any problems.
So the question is..............would you win your case? Well based on this statement about your use of their loaner, would a reasonable person also believe this may be the cause of the engine failure of yours?silverbullit05 wrote:here is my point i have owned and beat several different cars vw, hondas, volvos turbod, subarus and the funny thing is i hammered harder on all those vehicals then i ever beat on my g. i used to race the honda every day w/ well over 100k on the engine and in the course of a 3000 mile period car only consumed 1/2qt and after placing oil catch i found that was where it had gone. and the volvo 850 turbo has a leaky turbo oil return line and only uses 1 to11/2qts in 3000miles car also has 190000miles w/ original turbo. so my point is all my other vehicals are not only 4 or more yrs older than the g but the g only has 28000 miles and has been hardly beat on compared to the older cars not to mention burning 3 to 4 qts oil in less then 100 miles that engine should not burn a fraction of that in 3000 miles so the point is car has 7200 rev limiter i was 1200 rpms below that car should not knock. and it funny how its only 05 and 06 6mt engines that have this issue. when i asked the 07 coupe didnt have any problems supposedly. for a car that cost 10 to 15 grand more than most other cars ive owned i expect better quality. 40 gs is not exactly pocket change. however 07 sedan w/ hr engine is awsome not only is the car faster then all coupes but its much heavier. and no problem consuming oil. put it this way powertrain warrenty is 70000mile i will make sure the new engine does not used abnormal amount of oil as soon as it starts it will go back and i will get a lawyer. seeing the class action lawsuit is still pending.
I think we have already seen this pointed out, my point being that if you race the G in any way, it is one of the exclusions contained in the warranty, and just one of the exclusions that could prevent you from getting it fixed under warranty.silverbullit05 wrote:here is my point
Real is not to drive for over an hour knowing you have engine noise, then passing someone at high rpms under thiese conditions then pinning the failure on an engine part defect when the real problem may easily have been something like a plugged oil pickup which is an easy to fix issue and probably would occur in almost any vehicle under the same environmental issues.silverbullit05 wrote:well its funny how you dont own the model yrs that have the consumption issue but yet you act as if you never had ur car rev'd over 4grand. oh how many other cars do you no drink 3qts oil in 3000miles and its normal? get real perry!!!!!!!
Infiniti is actually very high on the reliability list. The facts seem to be that he could tell you that you did not have a plug inlet, but he couldn't tell you what did cause the problem. The idea of a plugged crankcase breather wasn't even in the equation I mentioned, oil return paths were. Did you tell them that you drove it for an hour like this and also did a fairly high speed run? Did you mention that you probably race this car just like you do their loaner. As far as 1 quart in 1000 miles, I be there are alot of cars that are raced and used more than that amount.silverbullit05 wrote:. hes the noise i herd when i started the car that morning is probly the contributing factor because he also enlightened me when he told me if the car sits for a few days then is started the engine has a period where not much oil is on the bearings for a couple seconds. however i was told i could not have changed any of the effects of that it was just a engine flaw. so all of your theory are WRONG! and wether i brought to the dealer when noise started or when i did the engine was going to need replacement. again i dont care that you have drivin a car for 41yrs doesnt make you an expert on oil consuption. and you never answered my question what other car manufacturer assuming engine broke in properly uses 1 qt oil every 1000 miles? do a search and the answer will be none! i have a lot of friends that work in dealerships that change oil and hondas, bmw even high compression e46 engine , mazdas and some others never had such an issue. i do know for a fact that there are many cars that use a small amount of oil like 1/2 to 1 qt in 3000 to 4000 miles in mostly city driving. but never 1qt per 1000miles. i bet if you went to every dealership near you and did a poll on oil consumption nissan and infiniti are the 1s with the issue.
I never said the others were caused by actions that may be construed as race related or not taking mitigating actions when a noise is present. However one is sure sounding more and more that way.silverbullit05 wrote:you are retarded!! ok i would understand your race theory if it was just my car that this problem has happened to however many g35's with 6mt have had engine transplants not just mine.
and just for the record when i got the car back the trans has a problem going into 5th gear so i took car immediately back and the tech had me go for a ride in the car and funny thing was i was told dont rev engine over 4000 and he was ramping it up to almost 5500 that had me a little pissed but he said it would hurt it. but im getting new trans to cause come to find out when they reinstalled engine something got bent.
You missed the point. The newly installed engine is new to your car, are you sure it is truly a 'new engine'?silverbullit05 wrote:the dealer was ramping the engine just installed with no miles on it. not my old knocking engine. so i would say if he was beaten on the new engine with no miles and not concerned it would cause an issue then obviously they must have fixed the oil issue. however that was not the way i wanted to start the break in period. especially when they told me not to exceed 4000 rpms. so now if the new engine fails im sure you will say it was cause i beat on it. and i have drivin car 120 miles and have not even brought it up close 3000 rpms. i will however after i hit 1200 miles will start verying rpms to the 4500 rpms.
Neon srt 4 General Motors? Reading about all of the problems you just mentioned with this particular car before you purchased it sounds like the car was a failure ready to happen. Whatever you purchase you better consider obtaining all of the maintenance records including a Carfax.silverbullit05 wrote:honestly i never considered piston slap. it sounded to much like a rod knock however come to think about it im curious. so i have googled infiniti and nissan vq35de engine issues and i found several interesting causes of failure but the 1 that came up the most was piston ring failure especially on the first year of rev up engine and the symptoms where said to sound like a rod knock. now i wish i would have done a compression test before bringing it in. now as to my new engine its brand new. not reman or used.
Not necessarily true. It is not unusual for those with a lease to only do what is absolutely necessary to full fill the requirements of the lease. For example since they know they have enough tread on the tires why purchase new ones? Why worry about other issues such as running the car through salt water and not rinsing if you are going to turn it in anyway?silverbullit05 wrote:
i figured buying a used lease vehical it be better then buying a car that had multiple owners.
