you can also stick a long screwdriver to the injector & the handle to your ear...
clicking? good
not clicking? wiggle the electrical plug to see if it does kick on... then presume it's bad
doing a resistance check @ the injector's plug would only test to see if there's continuity, not to test if it's working right or clogged
once you isolate the injector, you can either swap it w/ another one from the other cylinder & check again...
or just get a noid light to test the harness side of the injector system
PS: u know you can access the ecu on the passenger side kick panel & get the trouble codes yourself?
goto
http://www.240sx.org FAQs section...
