Engine revving too high in low speed acceleration
avatar77
Car: 2012 G37S Sedan; 2013 JX35
I'm sporadically experiencing this problem with my 2012 G37 sedan, 7AT, where I apply gas, the engine revs but the car does not accelerate - like the transmission is slipping. No sounds aside from the engine. It happens only when the car is already moving at relatively low speeds and under gentle acceleration. I've only ever noticed it happen when I'm going up or down a slope, like the ramps in a parking garage.
Typically, I'd think low transmission fluid but I've no reason to think that's the case as there's no indication of a leak or damage. Wanted to get some other opinions.
Squanto
Car: '07 Infiniti G35 Coupe 5AT
Assuming you haven't already found the answer to this (since it's been a couple weeks now) I'd say there's a chance it could be something like the torque converter. I had an automatic Acura CL that gave me a p0740 code which has to do with the torque converter. It then started revving real high without actually accelerating.
Not completely sure, but it's my guess!
avatar77
Thanks, I did check for codes and there are none. I will probably keep driving it with fingers crossed for the time being! I feel like sending the dealer to figure it out will just be a costly wild goose chase.
rics8
Car: 2009 Infiniti M35x
Clean from the gas the to the trottle. Royal purple and seafood for about a week and a half helped me and a Trans oil change
rics8
Clean from the gas the to the trottle. Royal purple and seafoam for about a week and a half helped me and a Trans oil change
rics8
