kerrton wrote:I believe that this is within design parameters, the CVT is protecting itself from damage when extremely cold by maintaining a low gear ratio and avoiding pressures from higher gearing.
Yup, this is totally normal and is the way the CVT is designed. By running more rev's the pressure/torque applied on the CVT internals is reduced which helps prevent excessive wear and damage. During very cold mornings, it may take as much as 10 minutes of driving before the revs will drop.
BTW, the increased rpms are the result of the TCM preventing the torque converter from locking up on low CVT fluid temperatures.
