PROJECTRB240SX wrote:ONE SCREW UP FRONT AND ONE IN THE BACK ON THE OPPOSITE SIDE OF THE MOTOR. I LIFTED THE ENTIRE CLIP LIKE THAT.
Ditto. The motor/transmission is almost perfectly balanced (no engine leveler needed) if you do it this way with even length chains. I couldn't find the grade 5 metric bolts tho... so I used bolts from elsewhere on the clip that fit those mounting holes. Only problem with this is that the front mounting point is really, really close to the fuel rail, so be careful.
Yeah, I had the flipped clip. I had to flip it back over in my garage using only an engine hoist, then check it out and say, "No, it's not gonna work," then get the trucking co. to come pick it up, then get another one shipped, then help the trucker slide the pallet onto the lift gate (because the pallet was trashed his jack wouldn't lift it), then get that clip off of the pallet, then pull the engine.... and now I'm waiting on another oil pan.
Fun stuff.
Shane
