One lift point is right above Cyl.#8, has 3 plugs on it.fatboybell wrote:I am getting ready to pull the engine out of my Q.The only question I have is where do you normally mount the lifting eyes on the engine to lift it out with.None of the bolts really look ideal.
I've seen people use a couple bolts in the holes for the knock sensor bolts as well.93 Q-SHIP wrote:Did you successfully pull your engine? out the top?
Please list the steps or list thread to instructions.
I dropped in the Complete engine and transmission as a unit from the top!Q45denver wrote:The mechanic that replaced mine, just wrapped the chains arounds the exhaust manifolds.
