Engine removal
Florida240sx
Is there anyway I can drop the engine out the bottom of the car? I don't have an engine hoist and I don't even have a decent enough tree limb around my house either. What would I have to remove steering assembly? Or is there just no chance of it going straight down. Because if I can get it to drop through the bottom I can swap the other engine in today.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
Sure is, the engine sits on the subframe. Disconnect the steering shaft, transmission mount, driveshaft, subframe, etc... and you can take the motor out the bottom. I think its way easier to just go to pepboys and fork over 200 bucks for a hoist, but more power to you for keeping it economical.
[s3]
J-Spec Tuner wrote:Sure is, the engine sits on the subframe. Disconnect the steering shaft, transmission mount, driveshaft, subframe, etc... and you can take the motor out the bottom. I think its way easier to just go to pepboys and fork over 200 bucks for a hoist, but more power to you for keeping it economical.
Yea, but how high does he need to jack up his car in order for it to drop.
Good luck, don't get crushed.
Florida240sx
Yea I just got under and looked at it.Shouldn't take too long should it to remove it?
JamesT
Car: 1992 Nissan 240sx
If it isn't a long-term job, you could look into renting an engine hoist. Call around and see if your local auto stores know where you could get one.
[s3]
Florida240sx wrote:Yea I just got under and looked at it.Shouldn't take too long should it to remove it?
I assume you have a lift?
If not, I would not attempt to jack the car up on concrete blocks.
The car would have to be raised substantially for you to be abel to extract the engine.
Florida240sx
I got a jack and 2 friends who can lift my car with ease they were able to pick it up off the ground with engine still in it so should be fine.
scheffler
Car: 92 240 KA-T
92 300zx TT
97 Tahoe
well thats one way to do it i guess hope you trust your freinds. good luck but i just did mine and i dont think i would have gone out the botom if i did it again have to lift car really high.
SMoKeM240
Car: 89 240sx NA/KA
i took my motor out without a hoist the first time, i just started stripping parts tell i had the block left and someone help me lift it out. didn't take that long either
