engine removal procedure?
niemczykj
Car: 1992 240sx fastback, 1986 Z31 Turbo
hi and thanks in advance for the help... and yes ive already searched but didnt get a clear answer...
so i bought a low miles KA and im going to swap it with my blown KA... im looking for an engine removal and insallation precedure for switching one KA24DE with another...
i have a 92 240sx fastback... 5speed manual transmission
Vernal
Car: (RIP) 1990 Hatchback 1989 Hatchback
niemczykj wrote:hi and thanks in advance for the help... and yes ive already searched but didnt get a clear answer...
Take out the engine wiring harness, intake tubing, disconnect vacuum, fuel lines, etc. Then disconnect your driveshaft, then unbolt the 4 17mm transmission mount bolts that bolt to the body. When it comes to the engine mounts take off the 14mm nut on the bottom side of the mount (It will be a hell of a lot easier if you drop the engine in with the mounts still on). Lift the old engine out with the transmission, then transfer the transmission over when the engines are out if you have to. Then do the reverse of what I said. Now this is no write up, but it gives you the general idea and order of the process.
