Engine Rebuilding Price
Neejay
Whats a reasonable price to rebuild an engine? I know for a dohc swap this shop quoted about $400. But I havent asked them about a rebuild yet. It would only involve bearings, piston rings, head gasket, and some valve adjusting. (with the installation of a intake and header while they're at it) [anything else major I need to replace as well?].
About how much should it be?
w1ngzer0
Car: Pfft. i don't own a box
well rebuilds cost from 1600-2200. They clean everything up and use a rebuild kit most of the time. If you want performance cams or anything aftermarket droped in while they are doing it they can drop it in for you.
Neejay
w1ngzer0 wrote:well rebuilds cost from 1600-2200. They clean everything up and use a rebuild kit most of the time. If you want performance cams or anything aftermarket droped in while they are doing it they can drop it in for you.
Ah, I was under the impression that I would give them the pieces I want rebuild/replaced and they would charge based on that (and/or per hour).
So usually a shop has its own process of rebuilding?
I was trying to decide on whether or not to just get a DOHC or rebuild this one.
Altiman94
Car: 1989 Nissan 240SX
most of the time they will want to provide their own parts. Warranty reasons
