240s_are_the_best »
https://forums.nicoclub.com/240s-are-the-best-u138388.html
Mon Jun 11, 2012 11:31 am
yes, i have quite a bit of build experience, I had the block honed but not bored, everything is standard size. i have already pulled the engine back out and i am going to tear it down tonight. the cylinder that has oil in it now gave me trouble building it. when i was putting the piston in, i believe it is cyl 5(driver side rear), i broke a ring, so i ordered a new set of rings from wiesco thinking that my ring compressor was the culprit. but maybe there is an issue with that cylinder, and maybe it broke this set of rings. but i think i would have noticed it like i did the other set?
also, the cyl right next to it (3? driver side middle) seemed to be missing also, but the plug on that one seemed to be firing correctly, but when i unplugged the coil it did not change the running of the engine.
when i unplugged number 1 (driver side front) the engine would stumble and almost die. same thing with all the cylinders on the pass side bank.
could it only be missing on the one cylinder (6), and due to the cylinders being side by side make it seem like number 3 is missing also?
