dhen wrote:Thanks, I appreciate that. I'll just stick with the regular gaskets then.
By the way, I've been searching all over the internet, and the only oversized pistons I can find are forged. I don't plan on running a lot of boost, but I want more displacement, are there any other options?
Thanks again,
Darian
If your dead set on forged pistons go ahead, but for the amount of boost your looking to run there isnt any need, hell you could run 20psi on cast pistons. And the .5mm bigger piston isnt going to net you any noticable results, turn your boost up 2 psi however, and it surely will.
