I have been shopping around to rebuild my engine, i have been looking at a few kits, THIS IS MY DAILY DRIVER!!! Affordable and Econmical is what i am looking for here.AMS KA24DE Advanced Rebuild Kit: $1709.20 (rebuild kit if getting turbo)
RPMRONs.com Platinum Kit: contains complete gasket set, set of pistons and premium rings, main bearings, rod bearings, thrust washers (if applicable), timing belt, balance shaft bearings (if applicable), and a set of expansion plugs. (does not contain: camshaft) with complete timing kit and oil pump: $913.10
Perfectengine.com: $653.55Full Overhaul Gasket SetPistons and Piston Ring SetPiston Pin BushingsFreeze Plug SetMain Bearing SetRod Bearing SetOil PumpTiming Overhaul Kit
