engine rebuild questions
im_looking_for_a_240sx
i'm doing a small rebuild on a single cam and wanted to know a few things.questions:do arp head studs for ka24de fit ka24e? or should i get stock head studs specifically for ka24e?get low temp thermo.? or stock?best place to get valve seals?(felpro ok?)Best place for bearings?(felpro ok?)is felpro the ideal brand head gasket for single cam?
gumby74
Studs are not neccessary. But I do suggest new head bolts. They were about $40 for a new set from the parts store.The complete Felpro gasket kit will work perfectly to include the head gasket. If you shop around online you can find the complete gasket set (pretty much everything top to bottom) for under $100. The kit should be available with the newer Viton valve seals and rear main.As for bearings, I am a Clevite man myself, but others run ACL as well as some other brands with success. The key is to take the time and Plasti-gauge the bearing surfaces. Don't just take the machinist word for it that everything is within spec. Unless you have no space to work in, in which case, do your research on the shop.I am fortunate that the guy that does my machining is a perfectionist. He understands that I will double check everything and send parts back on a whim. It's a love/hate kind of thing.
