engine rebuild question
VirginiaPS13
Car: 89 S13 Coupe
2005 Acura TL
long story short. I have a KA24e that was taken apart without the #1 cly. at TDC so I need to know the proper prcedure for putting an engine back together. nothing has been taken out of the block just the head was taken off for headgasket replacement and the machine shop took the head apart to clean and mill it. I am replacing the timing chain, oil and water pump, ream main seal. The engine is out of the car and on a stand. I just need to know how to rotate or to what position, does it matter the head has been taken apart, cam position?Please help!
maryjane
search!!!!!!!!!!!!!!!!!!!!!!
VirginiaPS13
Car: 89 S13 Coupe
2005 Acura TL
Dude Ive been a member here for a while, trust me I have searched. I cant find exactly what I need. Thanks for the bump though, but next time you dont have anything positive to add just hit the back button. Thanks have a nice day
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
Set the crank to the tdc mark on the block, set the cams at tdc according to their marks, install chain, and go, if you need more help than that then have someone else do it. Timing is one of the most easy things to do and one of the easiest things to screw up... good luck. If you had searched as you said you had then you would have found the threads I found that detailed this procedure. Search "KA24DE timing". Look through the threads...
Firewind
Car: 240SX
This should of had been the first and last reply.
http://www.nicoclub.com/FSM/240sx/91-94/
There's the factory service manuals. It shows you the correct step by step directions for rebuilding the entire engine.
If you don't have a 1991 to 1994 all the factory service manuals are located here zerothread/253879
Carefully read though everything, it's easy to forget or over look things, like I almost missed the fact that the piston ring gaps have to be pointed at particular directions, also some rings have an up direction and a down direction.
VirginiaPS13
Car: 89 S13 Coupe
2005 Acura TL
thanks guys
coupe240sxguy
Car: '89 240sx/ '01 mazda 626
or click on one of the links that i have below
420sxWETDREAMS
Car: 1991 240sx Hatchback
hey virginia what rims r on your piggy and what size they look really good?
VirginiaPS13
Car: 89 S13 Coupe
2005 Acura TL
They are volks, but its a photoshop job, because im poor..LOLbutI did just buy a set of mb battles that i havent put on yet.
SR24DET
Car: RMS13
Go to http://www.KA-T.org/forums. Then search engine rebuild. I followed a step by step walk through on how to do a DOHC rebuild and it has tons of pictures and everything. I havent looked for the SOHC, but I'm sure they have one. When I tried doing it with the FSM on here I got pissed because the correct info wasnt in the correct location. Timeing... Tourqe spec..... stuff like that.
