Engine Rebuild Problem
Dammit1323
Car: 91 Nissan 240sx S13 Coupe
Hi everyone! I just finished my rebuild on a Ka24de (1991). It looks like i have an idle issue. I don't know whats wrong with it. I turn the car on just fine. The timing is good. But when i press on the gas it kinda dies then gets back up. Also the intake makes a popping sound like its back firing. Can anyone help me find the problem please?
Also, I removed my EGR valve, install a plug on my exhuast and cap the vacuum lines, so I'm not running emissions. But my other question is should i cap all the vacuum lines?
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
yes lines capped, sounds like a few things, could be timing, a rich lean condition, or some sort of failed sensor. Are you able to check any codes at all?
Dammit1323
No I haven't look at it.
S13_RB25
Car: A 240 but no RB yet!
Actually my used to do that and it turned out that my intake cam was off a tooth, just double check that your timing is good.
Biggins240sx
Car: 1992 Nissan 240sx Stock KA24DE 180,XXX
Mine did that too when i first put it back together. Thought maybe a tooth off on timing? I was wrong. Base timing was off on distributor. I was at 10 degrees BTDC instead of 20 Degrees BTDC
