nissan240boy »
https://forums.nicoclub.com/nissan240boy-u182547.html
Wed Sep 21, 2011 9:04 pm
Ok so I have a 92 240sx with a ka24de and I want to turbo it but its starting to blow blue smoke so I figure I should pull the engine and somewat rebuild it, I have a new timing chain kit so thats goin on, next piston rings, valve seals, head gasket, and connecting rod bearings will be replaced, bearings are about 40 bucks, rings about 50, head gasket set 100, valve seals 25, and clutch disc bout 50 I figure while engine is out replace it, so maybe 300 for all this, now which brands should I pick, these are the brands I found on rock auto that are cheap, sealed power, beck/arnley, and dnj engine components, thank u and please give any info
