engine rebuild, am I missing a part?
progman
I'm finishing up my rebuild and I think I may be missing a part. In the FSM there is a part on the front of the crank shaft that goes after the oil pump but BEFORE the sprocket gear (for the timing belt). Then there is a part that goes on before the crank pulley. I don't have the part between the oil pump and sprocket gear.
I looked on everythingnissan.com and their illustration has all those parts except the one I think I'm missing. Is this part only on some models? Do I need it?
I fired my engine up as a test and the timing belt worked its way to the back of all the gears, it was hanging off by a few millimeters. So I took it back apart and I found I did not have this part.. did I maybe put the timing belt on backwards? or I'm a missing a part.
Thoughts?
Thank you.-Ben
I have these four parts, is there one missing from this picture???
where did this part come from?
Modified by progman at 5:12 PM 4/28/2008
boost_boy
You'll be needing that rear plate! You should be able to go to any nissan dealer and order it.
Dee
CakeEater
Car: '93 240SX w CA18, '08 Titan Pro-4X
Yes you do need the rear sprocket plate.
You stated at the beginning of your thread that you were missing the plate but you later stated you have it......If you have it then you will need to install it. If not, then go to the dealership and get a new one.
The belt will continue to slide off, and well....will never work without it.
Also manke sure that the slightly angled portion angles TOWARDS the oil pump. It is a little hard to notice, but if you don't put it the right way it will chew your timing belt to poo.
Hope this was a help man.
CakeEater
Here you go man:
Crankshaft plate (behind sprocket) - 13022-42L00 - $1.78
progman
Thanks guy, I'll be ordering that plate. Can't wait to finish this build!
Liquid_Neon
Car: 2000 Toyota Echo, 1988 Pulsar NX SE Turbo
yes plate is important. someone mine wasnt on when i did my first det swap and thats how my belt got chewed up im guessing. one junk head later i have elarned!
progman
did you buy one for it? remember where you bought it from. I called everythingnissan.com and they told me to e-mail them about it. I sent a picture from the FSM and everything. I'm waiting for them to call back. I'll call them again tomorrow.
biosehnsucht
I know you only need the rear, but here's the three pieces of the sprocket + its front and rear plates, since these are all often damaged or lost.
You can order them from Nissan with these part #'s, from a KN13 88ish Pulsar w/ CA18DE or CA16DE (these parts are identical)
PartCode Part# Description
Rear Sprocket Plate13021E 13022-42L00 PLATE-CRANKSHAFT SPROCKET
Crankshaft Sprocket13021 13021-D4200 SPROCKET-CRANKSHAFT
Front Sprocket 13021F 13023-42L00 PLATE-CRANKSHAFT SPROCKET
progman
Awesome, Thank you for that info. I sent it on the the guy at everythingnissan that is trying to find this for me.
progman
I got the part. Now the timing belt stays perfectly in the middle. I want to mention that the parts guy said there was like only 5 left in stock in the united states... so if you need one get it now. I bought both plates and the total was about $7.50
