rgk »
https://forums.nicoclub.com/rgk-u245656.html
Sun Aug 09, 2015 3:58 am
I second pulling the codes. Although the symptom is the same, it could be an issue unrelated to the IACV.
However, the symptom does point to it, which is frustrating. Here's what I think:
The TPS will likely cause shifting issues, but I haven't heard of it causing the car to stall. You can try unplugging it to see how the car runs.
Is the IACV OEM? Was it purchased new, used, or remanufactured? I doubt a new IACV would cause this problem three months down the line. The only "new" part that I ever had trouble with a few months down the road was a remanufactured starter, and I've purchased a lot of car parts. Even cheap Chinese parts last for at least a year, in my experience.
Speaking of remanufacturing, the part I would be looking at is the ECM. Seeing as how it was fried and refurbished, I would assume this to be your weak link. Is it possible for you to track down a cheap used unit for testing? Or perhaps send it back to your ECM doctor for diagnosis? Maybe you can just remove it and examine it yourself.
I agree that pulling the codes is your top priority. However, if I remember correctly, the idle relearn procedure is only relevant to 2003 and newer vehicles, as they were equipped without the typical cable throttle. Someone please correct me if I'm wrong.
Good luck and, as always, please keep us updated. :+)
