engine question
wordsayitagain
Car: 1993 240sx vert. hopefully hb soon.
I have a 1993 vert, i do not like it. its automatic. But im going to get a 1993 hb shell with a blown motor and a 5 speed trans. My question is if i take my motor out of the vert what all will i need to put it into the 5 speed car. The transmission is fine on the shell.
Thanks in advance for all the answers.
wordsayitagain
Ive been told pilot bearing. If that is all i need somebody please confirm. and dont say just swap to manual transmission. id rather have a hatch.
Jabberwocky
Car: 08 Subaru WRX
If you're asking that question you are probably going to need a nice chunk of money to pay a mechanic to swap the motor/transmission for you. Use the search feature to sift through older threads and writeups and come up with a parts list, it is not hard to find.
wordsayitagain
nah. i know how to swap engines. im just wondering what will be different since im swapping a motor to a car with a different trans
and i meant pilot bushing
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
As far as the engine goes you will need to install a pilot bearing. Also you will have to switch out the tps on the auto trans motor. (just use the old one on the blown motor.) Remove flex plate and install clutch and flywheel to new motor. You also have to use the m/t flyeheel bolts...flexplate bolts are too short. Thats it.
