michaelthepsycho wrote:It's "shifting" down into a lower gear ratio when it reads that you're letting off the gas a.k.a. you want to go slower. It's the same as a conventional automatic transmission down-shifting.
ding ding, circle gets the squaremichaelthepsycho wrote:It's "shifting" down into a lower gear ratio when it reads that you're letting off the gas a.k.a. you want to go slower. It's the same as a conventional automatic transmission down-shifting.
but minus whoopi goldbergLongBeachCoupe wrote:
And X takes the O!
I miss that show!
