Engine pull for upper oil pan?
CRyan
Car: 1997 Nissan 240SX
Just wondering if the job would be a bit shorter if there was a way to reseal the upper oil pan while engine stayed near the bay. I know it would have to be lifted somewhat, but just figured I'd ask what else would need to be done. . .Drop crossmember and that be it?
DuckyD
Car: 1995 240SX
The problem is that the motor mounts are bolted to the front subframe.
Here at the shop, we support the engine with one of these:
http://www.harborfreight.com/1000-lb-ca ... 96524.html
Then we are able to drop the front subframe and work on the engine.
This is an example of an SR20DET that we were working on earlier this week.
Noticed the previous mechanic took some liberties with the oil pickup haha We put an S14 SR pickup on there instead.
zach-Ka
Car: 1990 240sx (SR)
What kind of work are you needing to do?
DuckyD
Car: 1995 240SX
zach-Ka wrote:What kind of work are you needing to do?
CRyan wrote:...if there was a way to reseal the upper oil pan...
zach-Ka
Thank you sir, I have ADD and it's hard to take in what I read.
If you have a cherry picker then you can just unbolt the motor mounts and jack the motor up a bit and you should have plenty of room to do what you need to. You will have to remove the lower pan and oil pick-up tube before-hand though.
Hijacker
Car: '92 240sx Convertible
'94 F-150
DuckyD wrote:The problem is that the motor mounts are bolted to the front subframe.
I've redone many oil pans using one of those engine supports. It's also a great way to work on a timing chain without removing the motor.
CRyan
Thanks for the responses, guys. Tomorrow morning will be my time to shine, as they say. I have a hoist and will probably just let up off the engine mounts. I'll probably clean up the subframe, etc. I just hope to god this doesn't take more than a day to do. Anyone have an estimated time of completion? I have every tool needed, and a few experienced techs along with myself (not saying much)
Hijacker
'94 F-150
A couple hours should be the max. If you've got some good swivel sockets, you should be able to work around the crossmember without having to pull it. You just need to lift the engine up a little to get it off the mounts so you can reach some of the bolts and slide the pan out. Don't forget about the two hidden 10mm nuts behind the view plate in the bell housing area (it would suck to snap those and then have to pull the motor to replace the seal carrier).
CRyan
Hijacker wrote:A couple hours should be the max. If you've got some good swivel sockets, you should be able to work around the crossmember without having to pull it. You just need to lift the engine up a little to get it off the mounts so you can reach some of the bolts and slide the pan out. Don't forget about the two hidden 10mm nuts behind the view plate in the bell housing area (it would suck to snap those and then have to pull the motor to replace the seal carrier).
Wow, thanks! Knowing that makes me feel a lot better about doing this, without dropping the crossmember!
I think Hijacker has been my idol since the first time I looked at a 240SX.
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
On my S12, I wasn't able to get the pan to clear my crossmember, even jacking the engine up as high as I could. But maybe there's more room between the trans tunnel on an S13/S14.
