mmaxeyjr »
https://forums.nicoclub.com/mmaxeyjr-u91870.html
Thu Dec 11, 2008 4:37 pm
check you injectors, check timing (at distributor, and shine a timing light to make sure it's right). Also check all around the engine bay for vacuum leaks or any leak of any kind. Make sure all wiring for corrosion etc. Clean all plugs and connectors with a wire brush to take off any build up causing a poor connection.
Also check for exhaust leaks etc. etc.
Try unplugging the battery for a day (resetting ECU)
Seafoam...
Cheapest stuff first. If none of that fixes it, you're S.O.L
