cowbomb02 »
https://forums.nicoclub.com/cowbomb02-u10019.html
Tue Oct 21, 2003 2:32 pm
ok i just got a engine swap done for another ka24de motor in my 91 240sx. it was from a 93. after getting it installed there was a slight problem. the first day when the mechanic had turned the engine on he told me it was runing smoothly. he told me there were a few minor adjustments to be done so i decided to pick it up the next day. when i showed up the next day he told me there was a problem so he showed me . whenever he would rev the motor up, it wouldnt go farther then about 2500rpms. judging by the large ( more then normal ) amounts of fumes coming out of the exhaust he said that there might be a problem with the fuel injectors. he then stated that there could be some other problems but he wasnt sure. another thing i noticed when test driving it, whenever the car was idling it seemed like it was about to stall. the mechanic also found a broken ring from the cat if that helps any, but he replaced that. need some help guys thanks.
