spoolings14 »
https://forums.nicoclub.com/spoolings14-u87393.html
Sat Apr 26, 2008 10:12 pm
You sure you put the distributor in rite? TDC comression cylinder 1. Thats a problem i had wit my 95 S14, i had to accurately get it jus rite so it will work. Wat i did was TDC compression cylinder1, take distributor cap of, line up the dots on the dist. shaft and shaft housing, insert dist. and put cap over to see if the contact point lines up wit number 1 sparkplug.
