elwesso wrote:Does the car not accelerate above 2000...
If not, then your looking at many things.....
My engine is malfunctioning when hot, but (still) drives. It just hesitates terribly.
it does that between 1000rpm and 2000rpm,
it hesitates to when i accelerate with a kick down, it is like if the coil pack or injector is cutting one cylinder i sent that on acceleration.
when its rainning its more bad, i dont understand because theres no spark plug wired, 6 coil pack on 6 ngk platinum,
I try in the first time changing the plug it does anything,
oh yes almost forgot that the rpm going is unstable on idle sometime it run at 600rpm and sometime going up to 1000rpm .
Did you have this problem before
