If its shaking violently start with the cheapest fix, (plugs, wires, rotor, cap) but before you buy any of this do a compression test and see if you have a weak motor. If your motor is good and you have performed all of these tune-up related items you should start looking for a weak or a dead injector. Mine went 2 weeks after I bought the car. But I could still hit 80 MPH on three cylinders
. Start pulling your spark plug wires, one at a time, while your car is running, to determine where your weakest cylinder is at.
