engine problem
AMD 240
Car: 89 nissan 240sx coupe
hey guys im having a serious problem with my car. its a 86 200sx with the CA18ET. the problem is, i cant rev past 4 grand in any gear unless i floor it, but even then it runs really really really rich. if i dont floor it it just missfires and back fires. so far i have replaced the coils, cap and rotor.
i plan on running sea foam through the vac system to see if im having a leak somewhere. but other than that im lost to what could be causing this.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I moved this to the CA forum, i think you'll get better help. Good luck!
boost_boy
AMD 240 wrote:hey guys im having a serious problem with my car. its a 86 200sx with the CA18ET. the problem is, i cant rev past 4 grand in any gear unless i floor it, but even then it runs really really really rich. if i dont floor it it just missfires and back fires. so far i have replaced the coils, cap and rotor.
Be wary of your afm, Major vacuum leaks in either your intercooler piping (If you have a FMIC) or around your AFM, or the water temperature sensor.
Dee
AMD 240
thanks fro oving it. i wasnt sure where to post this since its an ET.
il be checking for vac leaks when i use the sea foam.
the mods to car are...CA18DET T25Greddy Type RS bovVolvo FMICMBC set to 11 psi
Ca_Silvia
Unwilling to rev in high rpm could be timing. AFM should cut around 2500rpm
kapower06
I bet its a vacuum/boost leak.
AMD 240
alright, i just got back from a good drive. car runs fine. but i know for sure its a vac/boost leak. now i just gotta find out which one it is haha
