steve s14 »
https://forums.nicoclub.com/steve-s14-u23089.html
Wed Feb 02, 2005 1:48 pm
if you have a volt meter, check the voltage of the battery with the engine running next time the idle starts to fluctuate. make sure the voltage is around 13v. sounds like it has a intermittent charging system problem. if the voltage is checked while the engine is running and the voltage reads below 12v, replace the alternator with a factory reman. do not get a pep boys or autozone special. although it's cheaper, you'll regret it when you find yourself replacing them all the time.
