Engine priming
MarkSilla28
Car: 1990 nissan 240sx s13 with a 1996 ka24de
:ohno: :sad:
Hello, I have a 1996 ka24de. Just rebuilt the engine and already put it in the car. I was told I needed to prime the oil pump. How would I go about doing that?
ca18det_boy
you can unplug the distributor and crank it over for about 30 seconds, or you can pull the fuel pump fuse and crank it over for about 30 seconds
MarkSilla28
Sweet! Thank you! This is my 1st time doing this on my own. And I still have to set timing once I get that going. I'll post pics when I can
MarkSilla28
Do i have to pull off the valve cover to make sure oil is getting to the top of the head?
ca18det_boy
nope, but you can if you really want to. It'll be a mess. If you cleaned the head prior to installation then you should be able to look through the oil cap and see pooled oil in the head after you crank it.
MarkSilla28
Okay perfect! Your a big help bro for real!
