engine price
Spidey
Car: my car
Hey I wanted your opinion on a S13 Sr20det price a friend of mine got. It is a RWD engine, transmission, and ecu motor set. it has been compression tested and the parts look decent. They asked 1400 for it. What do you guys think is it worth it or to good to be true??
Also I heard that the ecu sticker number had to 62 or else the ecu wouldn't work is that true??
thanks appreciate your help.
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
Where was this deal from? ebay? LOL.. If there's no wiring harness, forget it. I don't know about the ECU code but there's gotta be a reason why that thing is that cheap. I'm thinking its in bad condition, miss n matched parts, or no harness.
BuudWeizErr
Spidey, where are you getting your engine from? The ECU code is 62, so if it doesn't have that, it's the wrong ECU and make sure the harness, mafs and ignitor are there. I'm in socal too, so if you need any help, I might be willing to help out a fellow SR swapper. #61 is for the automatic transmission, so DEFINITELY don't try that one. If I were you, I wouldn't spend less than $2000 for a motorset. Call wayne at phase2, tell him ryan sent you, and he'll fix you up.
S13240
Wayne usually gets front clips only so it'll be a minimum chance of getting a complete motorset from Wayne.
Your best bet is to try cartune motorsports( http://www.cartunemotorsports.com ) or try SC Imports out in Cudahy (323) 560-3902 or (323) 560-4093 and ask for Nelson. I remember he had complete motorsets in for about $1700-1800.
BuudWeizErr
I got a motorset from Wayne for $2200.
Nismo_Freak
Car: 89 Nissan 240SX
Try Daunttless as well... he supplies full motorsets w/ intercoolers n stuff.
Spidey
Car: my car
your right there is no harness I took a look at it and like I said it looks decent. it is dirty though. The oil pan is good the turbo works and the sensors are all intact thanks for the help on the ecu.
RPS13Sideways
Car: 1989 Sileighty w/ '97 RPS13 Blacktop
I got a whole front clip for $1600 complete, is that worth it?
ItzGenX
As long as that clip had everything in it, and the engine was in good condition and wasnt abused to noticable hell.
RPS13Sideways
LOL, everything is intact and the engine looked in decent shape, and how could you tell it was beat to hell? I mean noticeable points? Let me know please...thanks...
BuudWeizErr
Open the oil filler and see if the cam lobe is scratched at all, take the valve cover off and see if it's real dirty or not, pull the transmission off and look at the clutch/flywheel/TO bearing, how dirty is the engine oil and transmission fluid... stuff like that.
RPS13Sideways
BuudWeizErr wrote:Open the oil filler and see if the cam lobe is scratched at all, take the valve cover off and see if it's real dirty or not, pull the transmission off and look at the clutch/flywheel/TO bearing, how dirty is the engine oil and transmission fluid... stuff like that.
Excellent, I will definately do that......thanks for the advice bro...how is your swap coming along?
BuudWeizErr
Waiting for my stupid friend to get home so I can go finish it up tonight, my FMIC got here yesterday and we get to bust out the saw and remove my chances of surviving a front end collision if I ever get into one. But my intake charge will be colder, so SCREW IT MUAHAHAHA.
RPS13Sideways
HAHAHAHA, screw the re-bar who needs em right? I just sold my B16A VTEC head for $140 ahahahhaha, straight blown valve seat and 2 bent valves......damn...can't believe I got that much.....good luck with your project
Silviagirl79
Car: I love Silvias, Skylines, Soul Calibur II, and GT3
RPS13Sideways wrote:LOL, everything is intact and the engine looked in decent shape, and how could you tell it was beat to hell? I mean noticeable points? Let me know please...thanks...
Did you order it from flash options?
jap drifter
is there a puck disc? if so, then yeah its probably been beat on
