C-Kwik wrote:Are you sure it was ping? There would have to be a serious hot spot for detonation to occur at 1/4 throttle. Carbon deposits maybe. Try putting in a tank of premium grade fuel. See if the problem goes away and perhaps that will confirm if it is indeed knock/ping. It should be able to run 87 octane without ping though. But I really just want to confirm if it is knock or not.
Thanks guys for your responses so far.
It was definitely spark knock. "clink clink clink" I had that once before on an old Oldsmobile, and the solution was to clean the EGR passages in the intake manifold -- the engine wasn't getting enough EGR. That doesn't seem to be the case here. But there was a discernable difference between the Bosch plugs and the Denso plugs, which leads me to believe that maybe the Bosch's were the wrong heat range...although they were the ones that were supposed to go on this engine. Bosch advertises that their center electrodes run cooler than other plugs, but I think that's what was heating up and causing a hot spot. I don't think it was pre-ignition, I think it was spark knock.
I could easily bring it on with the gas pedal. Push it far enough, and it would sound like a popcorn machine. Back off just a bit and the ping goes away. Ease on the gas again and it came back. It's the on-off threashold that differs between the two plugs. With the Bosch plugs, that threashold is pretty shallow (about 1/4 throttle). With the cooler Denso plugs, that threashold is much deeper, about 3/4 throttle.
I don't think this engine has a knock sensor (at least not on the truck). I'd certainly look into that if it had one. I can't find it -- if it does have one. Higher octane gas does solve the problem, as does colder temperatures, no A/C load. It's just under those most severe conditions, when it's 100 outside and I have the A/C on, and when I'm using more than 1/2 or 3/4 throttle (with the Denso plugs). I decided I'm not running those Boschs again...unless I can fix the spark knock. I also think that it's no big deal to run higher octane gas if it's supposed to be in the upper 90s for a short spell. I know the truck is "supposed" to use 87, though, so I'd like to be able to use 87.
I'll run a tank of injector cleaner through it, and use 92 octane this tank. We're going on a road trip with it this weekend, and I feel confident that I won't have any problems with the higher octane fuel. I had this problem before (severe ping, even at 92 octane), and discovered that the timing was set at 18* BTDC. When I set it back to 10*, truck ran great, no ping, even at 87 octane. And that still stands today...except on the hottest of days like we're experiencing this week. Even then, as long as I don't push the truck hard, it's fine.
Any other ideas. Again, I appreciate your comments so far.
Thanks,Jason
