mmmmm healthy motor lots O' calciumShionS14 wrote:what is up with your intake? those pictures look like you have calcium deposit on the intake side!
That is the exhaust side of the head. I'm thinking it's due to high temps or burning of coolant/oil.ShionS14 wrote:what is up with your intake? those pictures look like you have calcium deposit on the intake side!
That's what I wanted to find out. Everything checked in fine. Compression at 180psi across. No smoke coming out the tail pipe. One day my head started making a lot of noise. I thought it may be bad valves, so I decided to take the head off. Now I'm thinking that it may be oil somehow getting into the combustion chamber.wild_maxx wrote:thats alot of built up **** for 1500 miles..... were you burning any coolant or oil? What were the compression numbers before you pulled the head off?
There's some serious oil burning going on here. Either your turbo seal let go or your rings are shot. Compression pressures could be fooled by lots of oil getting by the rings. Check the outlet of the turbo compressor to make sure that's not filled with oil, next, I'd like to know how you're routing the valve cover pcv pipe. Done the wrong way and you could see mucho oil consumption. In the future, it would be nice if someone could follow you to determine if and when it smokes. Often, the driver never notices things like this as they're too focused on the road ahead and unless they can smell burnt oil never realize how bad a smokescreen they're laying down. Valve seal leakage is usually indicated under high vacuum conditions, i.e., going down a long hill with the throttle closed and then seeing a plume of smoke when you get back in the throttle. Bad rings and the smoke will occur under hard acceleration.gawath wrote:That's what I wanted to find out. Everything checked in fine. Compression at 180psi across. No smoke coming out the tail pipe. One day my head started making a lot of noise. I thought it may be bad valves, so I decided to take the head off. Now I'm thinking that it may be oil somehow getting into the combustion chamber.
The motor was not turbocharged. It was broken in all motor. The noise from the head sounded like bad valvetrain. Loud valvetrain tapping at idle and while cruising.dontbugme wrote:
What kind of 'noise' was the head making and at what frequency - engine speed or half engine speed.
The headgasket was a brand new felpro. The only other thing I can think of is that it wasn't torqued down tight due to the ARP head bolts.Nismo_Freak wrote:That motor had a blown headgasket and was leaking alot of coolant into the cylinders.
You will need to re-hone the block at least. There is a hot spot and a little bit of scoring on the cylinder wall. More than likely from a ring dragging.
Valve stem seals have not been replaced. I never saw any smoke while driving the car.wild_maxx wrote:have the valve stem seals been replaced? Was there any smoke while driving it? or just on accel?
